25 Sep 2023 07:02 PM
Hi
I'm sure this has been answered multiple times but for anyone still struggling with lag I've a possible solution
I've had the same issue... Playing rainbow 6.. Every few seconds there would be a lag I tried the new fifa (ea sports) lag every few seconds and then it would speed up. I tried all possible online solutions and found no answer. However what fixed mine was my ps5 was right next to my sky q box, this was undoubtedly my issue because once I disconnected the sky q box the issues disappeared after almost 7 months.
So one possible solution is if your ps5 is right next to an appliance which also using the WiFi, this could be causing the interference.
01 Nov 2023 03:46 PM
Hi there,
I've read through all the threads for advice and not found much advice that would solve the issues.
The house I'm living in has recently had Sky Fibre installed, and subsequently the main router being moved into another room. I used to use Ethernet (Great connection) but now I am stuck without it. I am getting horrendous connection on my PlayStation 5 as well as my PC. I've tried using Ethernet into mini boxes, which has made it worse. Without Ethernet, Sky seems like it cannot provide a good Wi-Fi service for consoles for online gaming. I've attached a screenshot of what I'm experiencing (high ms), and have plenty of videos of constant speed up lag on all games, and it's completely ruined my mood for the past month.
I'm not sure how upgrading to Fibre has made everything so much worse.
Any advice that doesn't involve spending more money on Amazon products would be much appreciated.
06 Nov 2023 03:52 PM
Posted by a Superuser, not a Sky employee. Find out moreIts nothing to do with your fibre connection its the fact you've gone from using ethernet to WiFi for gaming which isnt ideal at all. Depending on your location it could be that you have a lot of competing wireless routers around you or many devices in your home causing interference. Have you considered using powerline adapters to connect your console?
20 Nov 2023 08:42 PM
Nothing anyone can do if you use wifi . Sky seems to have gave customers a terrible router for something most people do on a daily basis, game . Sky will be getting ditched when out of contract after 14 years as a customer unfortunately .
20 Nov 2023 08:52 PM - last edited: 20 Nov 2023 08:52 PM
@Lauren111 wrote:Nothing anyone can do if you use wifi . Sky seems to have gave customers a terrible router for something most people do on a daily basis, game . Sky will be getting ditched when out of contract after 14 years as a customer unfortunately .
@Lauren111 Any ISP supplied router (unless it's from an aftermarket supplier, like Zen choose to do) is always going to be very average at best, especially when it comes to something like gaming. However, as other posts in the thread point out, anyone serious about gaming will always use a cable, nothing to do with an ISP supplying not good enough kit, but because of physics.
Wi-Fi uses radio waves. These are very susceptible to fluctuations/physical objects/other devices transmitting on the same frequencies that all clog the airwaves.
A cable, i.e Ethernet, is not subject to any such issues, and will give a far more solid, stable connection which is what gaming requires, as it is very sensitive to instability, that is inherent when using Wi-Fi.
20 Nov 2023 09:27 PM
I totally get that but I'm not buying it to be honest . My friends use bt / ee , no lag spikes and dropped internet like sky on ps5 playing the exact same games . I don't expect it to be perfect by any means but games like fortnite is unplayable and it's consistent .
my router is basically 10 feet away from the console with no obstructions , doesn't matter where I place it . Its got to be something with the sky set up or the router , internet generally seems fine with a constant speeds.
Search Sky Community
