Discussion topic: Newly installed Max Hub but my voip phone has a dial tone but does not dial out or reveive calls in
Message posted on 16 Dec 2024 05:45 PM
Having recently switched to Sky broadband and installed a Sky Max router, my Yealink VOIP phone, which is connected via an ethernet cable to the router, has a dial tone but will not connect to out going calls and won't receive in coming calls. The error on the phone says "Invite request no response!"
Message posted on 16 Dec 2024 05:56 PM - last edited: 16 Dec 2024 05:57 PM
Re: Newly installed Max Hub but my voip phone has a dial tone but does not dial out or reveive calls
There's apparently a firmware issue between the current Max Hub software release and some VoIP handsets. I'll escalate your post with a note that you probably need an alternative software version.
Message posted on 17 Dec 2024 08:36 AM
Re: Newly installed Max Hub but my voip phone has a dial tone but does not dial out or reveive ca...
Message posted on 17 Dec 2024 08:38 AM
Hi there, I am having exactly the same issue with my work handset, could i be included in the escalation please? I am currently unable to work from home due to this issue.
Message posted on 18 Dec 2024 12:26 PM
Hi I am having the exact same issues please can you escalate me also
Message posted on 18 Dec 2024 04:29 PM
I am also having the exact same issue as this.
Message posted on 19 Dec 2024 09:32 AM
Thanks for escalating this. We’ve sent an invite to chat.
Message posted on 20 Dec 2024 05:14 PM
I'm also having this issue, please can someone escalate for me? I have tried to speak to the technical team multiple times, however they all say different things. Ended up reducing security etc and final call said that it's because the Sky Max Hub isn't compatible with VOIP phones unless plugged directly into the router. Work IT team say that's not correct as the VOIP phone I have is internet only.
Message posted on 20 Dec 2024 05:54 PM - last edited: 20 Dec 2024 06:04 PM
That's a misunderstanding of Sky Talk Internet Calls, which is the built-in analogue to digital conversion (ATA) through the BT jack port and unrelated to a 'real' VoIP handset using ethernet or WiFi. I'll escalate your post.
Message posted on 21 Dec 2024 04:36 PM
Thanks for escalating. We've sent an invite to @Es-.
Tom
Message posted on 21 Dec 2024 06:27 PM
Hi Tom, it won't let me reply to your message..? It says to correct the errors on the page (which doesn't then show where the error is) plus users haven't enabled PM- but I can't see where this needs to be enabled?
Message posted on 24 Dec 2024 02:01 PM
I have the same issue, please escalate as I am on call over Christmas and cannot work
Message posted on 24 Dec 2024 02:27 PM
@kevinwicnott To get you some help with this I have escalated your post to the Sky Messaging team. This link explains how it works https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M1014
Keep an eye out for an invite or blue chat bubble.
When the blue bubble does appear you have 48 hours to respond or it will be automatically closed.
Be reassured the email & message is from Sky and your details are safe and secure.
If you are using Safari please make sure that Hide IP Address is not checked in order to see the blue bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
I would also recommend that if not already on, that you turn email/private message notifications on to avoid missing any alerts
Message posted on 24 Dec 2024 02:28 PM - last edited: 24 Dec 2024 02:29 PM
@Es- Which browser are you using?
I would also try using private or incognito mode
Message posted on 24 Dec 2024 02:29 PM
Hi there! Thank you for escalating this. We have sent an invite to @kevinwicnott.
