Discussion topic: Sky hub blocking gaming
Message posted on 09 Jan 2025 10:20 AM
I am having an issue where if I am on a direct connection through my sky router games like Dayz or PUBG won't connect to a game server. If I run nordvpn I can connect before gettig kicked for using a VPN. So there is something odd about the direct SKY connection. I turned of Sky Shield completely but that doesn't seem to make a difference.
Message posted on 09 Jan 2025 12:26 PM
Re: Sky hub blocking gaming
What do you mean by direct connection? Just without VPN? Or using ethernet rather than WiFi?
Message posted on 09 Jan 2025 12:30 PM
Both wired and wireless. The hub seems to block access to the game servers. Apparently something to do with firewalls. I've turned things off and put it in DMZ and still nothing
Message posted on 09 Jan 2025 01:12 PM
Which Sky hub do you have?
Message posted on 09 Jan 2025 01:14 PM
The white one
Message posted on 17 Feb 2025 11:27 PM
Same issue
Message posted on 18 Feb 2025 02:30 AM
Some people have been having issues with PS5s too, I wonder if they have the white router. I have the black router and my PS5 PRO and PC works fine.
You people may be onto something with the white router being the cause.
Message posted on 18 Feb 2025 07:09 AM
@JordanNewton & @7Jackarmy1 check the settings in the Broadband Shield section of the My Sky app as if set to a low age it will block online gaming. There is nothing in the white hub which behaves differently in regard to gaming.
