Discussion topic: WiFi strength
Message posted on 17 Feb 2025 09:17 PM
WiFi strength
Recently had WiFi fibre installed and also WiFi max , since then my WiFi strength has been worse once I move 30 ft from the hub my WiFi signal goes.
Message posted on 18 Feb 2025 07:22 AM
Re: WiFi strength
@Nothappy5 if you are paying forvthe WiFi Max bundle Sky will supply extender pods if you need them just give them a call. 30feet of air should be no problem but add in a solid internal wall or two and it is pretty certain wifi spedds will drop. The denser the wall the greater the signal loss.
Message posted on 19 Feb 2025 06:56 AM
Re: WiFi strength
Thanks....I'll give them a call
