Discussion topic: Can connect Wi-Fi booster to hub but password is required which is not my Sky hub password
This message was authored by Ingramm3 This message was authored by: Ingramm3
Can connect Wi-Fi booster to sky hub via WPS but to connect to booster it requires a password which is not the same as my Sky modem....any clues?
Re: Can connect Wi-Fi booster to hub but password is required which is not my Sky hub password
@Ingramm3 if its a Sky booster then it will use the same password if properly connected. Third party boosters it is down to whoever made it. Can you connect devices using wps?
