Discussion topic: I’m not getting any broadband
Message posted on 01 Mar 2025 08:40 PM
My broadband isn't working
Message posted on 01 Mar 2025 08:41 PM
Re: I’m not getting any broadband
@KatherineClark
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
Message posted on 01 Mar 2025 08:52 PM
It's still not working
Message posted on 01 Mar 2025 08:54 PM
You may need to call Sky then. To call Sky dial 150 (free) from your Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
