7
This discussion topic has been answered Discussion topic: Trying to turn off 5Ghz
This message was authored by: teddyman
I want to connect several items that use 2.4ghz so need to turn off 5Ghz to do this.
There are no hub admin controls on the MySky app. Fibre went active about lunchtime today.
Any advice??
Avatar for teddyman
This message was authored by: teddyman Answer
Re: Trying to turn off 5Ghz
@teddyman the need to use the My Sky app only apllies if you havectgecwhite Sky Max hub. The black hubs are controlled through their web inerface see Split Sky WiFi bands
If you haveca white hubs sign out and exit thecapp and then reload it as the settings should appear under Product Options if they dont you need to call Sky to get them added.
This message was authored by: FLC
If your Hub has not yet been assimilated, then you should be able to make the required changes in the web interface. 192.168.0.1 into a web broswer & login with username admin & the WiFi password.
Avatar for teddyman
I have a white Skymax hub.
Where would I find the hub username?
@teddyman
Avatar for teddyman
All
sorted now thanks
This message was authored by: Campingmad
Hi, how did you solve this problem.  I have just gone to fibre and have a dongle that I cannot link as it needs to be2.4?
@Campingmad simply log into the My Sky app find the page for the Hub's advanced settings and you will see the link to switch off the WiFi. Turn off the 5GHz band connect your donglecand turn the 5GHz band baxk on and the dongle should stay connected.
