Discussion topic: Internet not working
Message posted on 01 Mar 2025 07:23 PM
My internet is not working I have unplugged it and I have reset it and still not getting anything.
Message posted on 01 Mar 2025 07:26 PM
Re: Internet not working
@Nicky66
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
