This discussion topic has been answered Discussion topic: Sky Max Hub not showing under products
Message posted on 17 Oct 2024 07:07 PM
Re: Sky Max Hub not showing under products
Took over a month to gey landline and website sorted. Still not getting advertised WiFi or stability 👎
Message posted on 17 Oct 2024 09:19 PM
My speed is fine ( wired ) but I have had to wire in my Sky Q boxes as they won't connect or stay connected( luckily I have network cables installed for Consoles, Gaming PC etc )
Very poor service considering it's a monthly charge 😞
Message posted on 17 Oct 2024 10:58 PM
All my problems started after 'upgrading ' to fibre from copper. Bad decision, but as copper is going away, it's now or later 🤔
Message posted on 18 Oct 2024 09:49 PM
I'm having the same issue with no sky max hub settings in the app, no speed results on connection test and none of the advanced security settings etc working. I've been told by sky today that their network team are rolling out a blanket fix to resolve this for everyone and to wait 24 hours but I'm not convinced if this has been going on since May for some people. I've only been with sky since 10th Oct after moving from another provider and I'm somewhat regretting my decision at the moment
Message posted on 18 Oct 2024 10:09 PM
Same problem here,
Ihave been told today that it is a widespread and long term problem with no resolution date or time frame.
I ordered the Max hub for the added security and controls, so I'm nit getting the product advertised.
This is quite bad from Sky as no where was it mentioned that the Max hub is having technical
problems before purchase.
Message posted on 18 Oct 2024 10:35 PM
Sky won't tell you that, ot you won't buy it. They blamed OpenReach for my landline issue, but couldn't explain why app /website had no product info or capabilities. It just showed up after a month, no fix or reason given.
Message posted on 18 Oct 2024 10:40 PM
Same line I was given. Wide-spread issue, OpenReach working it, etc. Worst fibre provider I've ever had. It will be more than 24hrs before you see a fix. Don't let them gaslight you into thinking that clearing the mySky app cache, then reinstalling it, will fix anything. It won't. Call every day requesting an update, and eventually your problem will get fixed. Good luck.
Message posted on 18 Oct 2024 11:43 PM
I shall keep calling, I will give them a week then I am going elsewhere.
I understand companies have problems but to be lied to on numerous occasions is unacceptable.
Message posted on 19 Oct 2024 12:48 AM
I'm having the same problem - the hub is connected, working fine, and shows when I run checks etc, but there are no settings available in MySky, and which appears to be stopping my booster from working as well.
Message posted on 19 Oct 2024 06:26 PM
It would be interesting to see how widespread this problem is.
Message posted on 19 Oct 2024 06:45 PM - last edited: 19 Oct 2024 06:47 PM
It's reported here several times a day, but without any visibility of how many MX Hubs Sky is sending out it's impossible to know what kind of percentage of recipients are affected: probably rather small given Sky Broadband has around six million subscription households.
Message posted on 21 Oct 2024 01:38 PM
lol the app just sent me a notification to setup my WiFi
mickey taker
Message posted on 21 Oct 2024 01:44 PM
Phoned today and apparently it's a thing they know about and are fixing, but if the fix the phone people have doesn't work, it needs escalated to an engineer. Sure as eggs is eggs mine didnt work. We'll get there though. 😄
Message posted on 21 Oct 2024 04:57 PM
All roads lead to OpenReach...good luck
Message posted on 30 Oct 2024 04:52 PM
Spoke to Sky again yesterday. They sent me a WiFi Max Pod. Guess what. Yep you need to setup the Max Hub before the Pod works.
Still no sign of being able to setup the hub in the MySky app
