Discussion topic: WiFi not working
This message was authored by: PedroBandito77
WiFi not working
WiFi isn't working, have reset router and powered it off for a while. Have green lights on 1 and 3 but 2 and 4 are off or flashing orange occasionally
Re: WiFi not working
@PedroBandito77
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
