Discussion topic: No Wi-Fi in bathroom
This message was authored by JMb03 This message was authored by: JMb03
Hello I can't reach broadband in my bathroom as it is shocking.
I ubderstand my bathroom is furthest if the house but I need a connection to make it faster in a bedroom.
thank you.
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No Wi-Fi in bathroom
@JMb03
You may wish to research subscribing to Broadband Boost
Sky Broadband Boost | Sky Help | Sky.com
▪️I AM NOT A SKY EMPLOYEE ▪️
Surely you don't need wifi to extend to the bathroom? It's really only got 2 uses.
@JMb03 Getting decent wif coverage through out many homes requires additional kit. Sky boosters can help in some homes but have limited use to be honest. You can buy whole home wifi systems that can replace your Sky hub's wifi which need not break the bank my 3 unit system cost under £100.
Word of warning if your home has foil faced plasterboard used in the bathroom walls you will always struggle to get a wifi signal in there. Solid brick or stone pose problems but a thin layer of metallic foil is as bad.
@GD1 for many people the bathroom is a rereat from the pressures of family life.
