Discussion topic: Bad WiFi coverage to ring doorbell was ok with BT wifi
Message posted on 08 Jan 2025 05:45 PM
My ring doorbell looses WiFi connection all the time have moved to WPA2 to suit ring doorbell 3
Message posted on 09 Jan 2025 07:29 AM
Re: Bad WiFi coverage to ring doorbell was ok with BT wifi
@KC42 doorbells are frequently an issue as bybdrfinition they are outside the home often on a double brick wall. Not sure why the Sky wifi is apparently weaker then the BT service it replaced. Sometimes its down to positioning or the use of boosters or simply luck. It is worth rebooting your Sky hub to see if it can find a 2.4GHz channels with less interference but tgst can be a temporary solution.
`I would talk to Sky raise the issue with them they can supply a packageccalled Sky WiFi Max which can provide up to e extenders fitting one in the hallway might help. See https://www.sky.com/help/articles/sky-wifi-max
