Discussion topic: Amber light on router
This message was authored by: Scottyc95
Message posted on 08 Jan 2025 07:12 PM
My internet light is amber and I called and they said there is fault. could take 5 days to fix
Find out more
Message posted on 09 Jan 2025 07:33 AM
Re: Amber light on router
@Scottyc95 unfortunately it is quite likely that an area fault can take 5 days to fix especially at the moment due to the backlog generated by the holiday and the recent bad weather Openreach engineers are very busy. However you should be due compensation if it isnt fixed by Monday see Customer Auto-Compensation | Sky Help | Sky.com
