Discussion topic: Require SIP ALG/MAP-T to be disabled
Message posted on 09 Jan 2025 08:57 AM
Hi my IT department needs to ask Sky to disable the SIP ALG on your Sky Max router to enable your VOIP phone (provided by Gamma Global if they need to know) to function. They may also need to disable the MAP/T (according to some posts on a support forum). I have tried phoning them and they said this is not possible, has anyone experienced issues with this before?
Message posted on 09 Jan 2025 09:27 AM
Re: Require SIP ALG/MAP-T to be disabled
@AmberL1 according to the lastest update from Sky the issue with SIp is not with MAP-T as such and has been solved byva firmware change. You should be contacted by Sky later today to check your setup.
Message posted on 09 Jan 2025 10:21 AM
Thanks for escalating this. We’ve sent AmberL1 an invite to chat.
Lisa - Sky Tech Team Expert
Message posted on 16 Apr 2025 12:26 PM
I'm having the same proble.n someone contact me please.
