Discussion topic: Smart TV keeps dropping out of broadband coverage then reconnecting.
This message was authored by: KDRobinson
Sky puck connected to my smart TV keeps dropping out of connection with my hub then reconnecting. Any ideas if there is a wider issue with Sky full fibre broadband?
Re: Smart TV keeps dropping out of broadband coverage then reconnecting.
@KDRobinson almost certainlybpoor WiFi signal  to the puck. To test run the Network test in the Get Help menu of the Netflix app. You needcat leastv25Mb/s to watch UHD contrntvand ideally around 35Mb/s. You can improvecthings by making sure both the hub and the puck are out innthe open so not hidden behind the TV.
If tgst diesnt help,and using ethernet cables are not practical you may need somecform of WiFi extender like theones Sky can orovide as part of the https://www.sky.com/help/articles/sky-wifi-max
