30 Mar 2023 02:35 PM
Hello,
Does anyone know why my WiFi signal drops when someone phones me on my landline (which is also with Sky). I always have to wait a few minutes and try and re-connect my Sky Q box and other devices connected to my home internet via WiFi?
30 Mar 2023 03:06 PM
Posted by a Superuser, not a Sky employee. Find out moreDoes your phone connect to the socket on your wall or into the Sky hub?
31 Mar 2023 02:45 PM
31 Mar 2023 02:47 PM - last edited: 31 Mar 2023 02:47 PM
Is the 'landline' connecting to a fixed telephone handset or a DECT cordless phone base station?
31 Mar 2023 02:59 PM
31 Mar 2023 03:01 PM - last edited: 31 Mar 2023 03:02 PM
That would be the primary suspect, then. You don't want this anywhere near the Sky Hub.
For an FTTC connection you'd also want a filtered master socket or a plug-in microfilter.
31 Mar 2023 03:03 PM
31 Mar 2023 03:04 PM
On the same socket or an extension, and is it behind a filter?
01 Apr 2023 04:04 PM
It's in a completely different socket. I wouldnt call it an extension as the both sockets were put in when it was build, about 15 years agoi
01 Apr 2023 04:38 PM - last edited: 01 Apr 2023 04:40 PM
Posted by a Superuser, not a Sky employee. Find out moreUnless you have two phone numbers, it's an extension socket. A phone plugged into an extension should be on a microfilter if the master socket isn't a prefiltered model: this should remove the possibility that the phone ringing is knocking the router offline.
