Discussion topic: Internet issue
Message posted on 13 Mar 2025 10:35 PM
Internet issue
Devices are connected to my hub but no internet access. Lights on hub and fibre box look okay. When I test using the sky internet checker it says it is okay but there is definitely an issue. It suddenly stopped working on multiple devices at once.
Message posted on 14 Mar 2025 04:51 AM
Re: Internet issue
@Chris498
Message posted on 14 Mar 2025 07:57 AM
Re: Internet issue
Thank you for the info . I have tried it all. Broadband and WiFi say they are all good on the checker but no internet. The hubs voice light is solid amber.
Message posted on 14 Mar 2025 08:14 AM
Re: Internet issue
Sounds like you'll need to report it. If your landline isn't working then call Sky by dialling 150 (free) from a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
