Discussion topic: My WiFi is down yet again.
This message was authored by: Nick+Coy
I've done numerous tests and it says no problems but there is an orange light on my router and it's not working. This happens too frequently and given the amount of money I'm paying it is not good enough
Re: My WiFi is down yet again.
@Nick+Coy
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not up and running by 7ish use the below link to check to see if there are any problems or outages nearby
