Discussion topic: No internet connection
This message was authored by: Oleh1
I tried to check on the app, and i said all working, but when I tried to connect it said no internet connection. Also light in broadband over the internet is no ligh.
Re: No internet connection
@Oleh1
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned in the morning use the below link to check to see if there are any problems or outages nearby
▪️I AM NOT A SKY EMPLOYEE ▪️
