Discussion topic: No internet connection
This message was authored by: Sadi92
From midnight there is no connection. Router light turned orange. Have reatarted router, still same. Whats going on?? Have important meeting session in morning and i am preparing, now no internet!!!
Re: No internet connection
@Sadi92
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it doesn't return in the morning use the below link to check to see if there are any problems or outages nearby
