Discussion topic: No internet connection
This message was authored by: Tanaya
Internet down
Re: No internet connection
@Tanaya
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back in the morning use the below link to check to see if there are any problems or outages nearby
