21 May 2022 05:18 PM
Hello, I currently have Superfast however I am wanting to upgrade to Ultrafast Plus. I have a few concerns:
1) Will this cause disruption to my preexisting internet connection? I work from home remotely and would need internet access throughout the day, would this work cause the internet to go down?
2) How long is the process to get it installed? Is it a simple process and what access is required to install this from the engineer?
Thanks again anyone who manages to reply ❤️
21 May 2022 05:42 PM
Hopefully not maybe an hour or so. But sky still will state up to midnight on activation day to go live.
21 May 2022 05:21 PM
Enter your full postal address below and post the table and notes after removing your address from the image
This will give an idea of timescales and any known issues
21 May 2022 05:25 PM
Ive attached said table!
21 May 2022 05:30 PM
1 stage install usually 7 days from date of order. Single dwelling overhead feed and no known issues
And certainly it shouldn't take as long on date of activation to cease the fttc line and get your fttp activated as it would for switching providers. Hopefully one to two hours max.
21 May 2022 05:35 PM
Would I experience the internet being down during this time? Thank you so much for your answers
21 May 2022 09:42 PM
When I went from Superfast to Ultrafast, the broadband continued to work while the fibre was installed as it's a new network. The only disconnect was when the engineer rebooted the router to swap from the copper fed line to the ethernet link between the ONT and router - around 5 mins.
