Discussion topic: Poor WiFi connection around the house
Message posted on 04 Mar 2025 10:13 PM
Message posted on 05 Mar 2025 06:18 AM
Re: Poor WiFi connection around the house
@MarkProctor Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
