Discussion topic: Sky Max Wi-Fi Hub connect to Sky Q box via Wi-Fi.
This message was authored by GeoWolf58 This message was authored by: GeoWolf58
Had a visit from a Sky Tech expert today. Mentioned about Sky Q Box not connecting via Wi-Fi to new ( white ) Sky Max Wi-Fi Hub.
He said the Hub is not user friendly, and the instructions are vague!
He also said the WPS button on the Sky Max Wi-Fi Hub shouldn't be used to connect to the Sky Q Box, it does not help the reset.
What you should do , is go to Set Up , then Network, then Status.
Select the 2nd option, not the top Sky option.
You will then be asked for your Sky Hub password details. Enter and carry on.
This message was authored by M4g This message was authored by: M4g
Re: Sky Max Wi-Fi Hub connect to Sky Q box via Wi-Fi.
I had to do this too 👍🏼
This message was authored by Christine14 This message was authored by: Christine14
Thanks for this, it worked for me too.
