Discussion topic: Connecting issues
This message was authored by: Deancole1979
Connecting issues
Hi , we have connection issues in other rooms - seems like the hub is just not strong enough to service the entire home .
the pucks even disconnects saying no WiFi when the hub lights are white and on .
puck sometimes makes a strange noise .
home testing is saying all is good but something is wrong
Re: Connecting issues
Hi @Deancole1979
Which hub do you currently have and have you always had this issue with WiFI range?
I am NOT a Sky Employee
Avatar for Deancole1979
Not sure if tou got the last message
 Thanks for the rely
its the white router with the black pucs that cam with the fast fiber  BB thst i had installed in november / december 2024
yes its never been the best
@Deancole1979 Seems like you need some booster pods to cover your home. You can claim these for free if you have the wifi max addon
Hi , I do .
how do I get them ?
@Deancole1979 you need to speak to sky. I have escalated your post to them. Look out for a message on the forum to chat.
Thank you 👍
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @Deancole1979 an invite to chat.
