Discussion topic: Network not showing
This message was authored by: Tinabop2
Network not showing
I can't connect to my WiFi you say everything is working . But my alexas are offline the hub isn't showing on line and I connect anything to the WiFi
Re: Network not showing
@Tinabop2
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
