Discussion topic: Tv keeps freezing
Message posted on 04 Mar 2025 07:48 PM
Tv keeps freezing
tv runs off of the internet and it keeps freezing and loosing it's picture and a round symbol apears when loading in the centre
Message posted on 05 Mar 2025 06:32 AM
Re: Tv keeps freezing
@Stuart136 Streaming TV requires a good strong wifinsignal or use of ethernet cables. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
