02 Jul 2022 03:58 PM
With Passport plus do I have to pre purchase the days before I go, does it work automatically or do I have to do something when I'm in Spain?
02 Jul 2022 04:15 PM
Posted by a Superuser, not a Sky employee. Find out moreIt's automatic upon use : https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Ensure spend cap doesn't prevent usage.
05 Jul 2022 04:25 PM
Have a spend cap set up based on the number of days you are travelling. After some new regulations set up due to Brexit you would have a roaming charge of £2 per day. So the best advise would be to set the cap based on the number of days you're going to be in Spain i.e. if it's 7 days you're going to be there set your cap at £14 or for good reasons at £16 and if you have more than 1 sim with sky and other sims are also in Spain cap all of them based on the number of days(£2 x number of days= spend cap). And once you land in Spain try to make a call or to turn on your mobile data and it would automatically trigger the roaming passport plus for the next 24 hours and it reactives automatically as well.
