4
This discussion topic has been answered Discussion topic: Can I post on Instagram and Tik Tok while in Tenerife
This message was authored by: Kassie333
I understand the £2 daily change for Roaming but what other charges might there be?
This message was authored by: 63johnw Answer
Re: Can I post on Instagram and Tik Tok while in Tenerife
Hi @Kassie333 using data on apps will trigger the £2 daily charge. Sending pictures via WhatsApp or iMessage would use data and trigger the £2 daily charge but nothing more. Sending mms picture messages isn't included and would be extra. Calling local numbers would be charged extra.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
No others.  You need to have enough data though.
Best to use WiFi if you can.
Avatar for Kassie333
Thank you for the reply - data is no issue I have loads in my Piggybank!
So if my granddaughter posts on TikTok or Instagram in Spain it's included in the data?? Also what about sending pictures or videos?
The £2 daily charge allows you to access your package as if you were in the UK so anything that uses mobile data will use some of your allowance needs your use Wi-Fi.
