2507
Discussion topic: Netflix has encountered an error. Code: tvq-st-102
This message was authored by Kevin_1990 This message was authored by: Kevin_1990
Re: Netflix: Red Spinning Circle on Launch
Mine end up loading up later on in the night
This message was authored by jumpscoach1 This message was authored by: jumpscoach1
Can't 'open' my Netflix app. Just getting that annoying red circle going around and around..
Can't 'open' my Netflix app. Just getting that annoying red circle going around and around. I'm paying for the service through my Sky subscription. This has been going on for over a month. So frustrating...
Re: Can't 'open' my Netflix app. Just getting that annoying red circle going around and around..
@jumpscoach1
I have moved your post to this large topic where this issue is being discussed in the Sky Q forum. There is a possible fix here in the second post:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4694387/highlight/true#...
This message was authored by Chodley This message was authored by: Chodley
@G-Man99 wrote:
Ok tried exiting Netflix app from the menu in sky app.
I don't understand what this means - you can't access the menu in the Netflix app on the Q box if its stuck in red spinny circle mode, can you?
This message was authored by G-Man99 This message was authored by: G-Man99
@Chodley I have to power off the skybox and back on then Netflix loads as long as you have not accessed other apps
How long does that work for?
This message was authored by Budda08 This message was authored by: Budda08
It's not a fix, but a quicker workaround if netflix isn't loading (rather than rebooting sky box) is to open any other streaming service and then opening netflix.
Works everytime.
Works everytime.
Some other people have had luck with that too but some not. It's weird.
This message was authored by Cazziekw This message was authored by: Cazziekw
Re: 2nd Q box issue
Got it sorted, finally got through to customer service and they talked me through doing an app refresh. Sttings update then app refresh worked. I had to sign into all of my apps again but at least it worked.
This message was authored by Matt19761 This message was authored by: Matt19761
Netflix not starting up on the Sky mini box
Netflix not starting up on sky minibox
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Netflix not starting up on the Sky mini box
Red spinning circle?
I am just another Sky customer and my views are my own
Yep. Red circle going round and round  and round etc etc
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Matt19761
I've moved your post into a large thread discussing this issue. Please see the post (number 2) currently showing as the answer.
This message was authored by MegandjakeY123 This message was authored by: MegandjakeY123
Re: NETFLIX ON SKY NOT WORKING
Hi my netflix in bith sky boxes will not work. It laods woth the red circle movikg thsts it. Happened now for over a week very frustrating tried everything
@MegandjakeY123
