Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 18 Aug 2024 12:33 AM
Re: Netflix: Red Spinning Circle on Launch
Mine end up loading up later on in the night
Message posted on 18 Aug 2024 09:59 AM
Can't 'open' my Netflix app. Just getting that annoying red circle going around and around..
Can't 'open' my Netflix app. Just getting that annoying red circle going around and around. I'm paying for the service through my Sky subscription. This has been going on for over a month. So frustrating...
Message posted on 18 Aug 2024 10:17 AM
Re: Can't 'open' my Netflix app. Just getting that annoying red circle going around and around..
I have moved your post to this large topic where this issue is being discussed in the Sky Q forum. There is a possible fix here in the second post:
Message posted on 18 Aug 2024 11:34 AM
@G-Man99 wrote:Ok tried exiting Netflix app from the menu in sky app.
I don't understand what this means - you can't access the menu in the Netflix app on the Q box if its stuck in red spinny circle mode, can you?
Message posted on 18 Aug 2024 06:59 PM
@Chodley I have to power off the skybox and back on then Netflix loads as long as you have not accessed other apps
Message posted on 18 Aug 2024 09:59 PM
Message posted on 18 Aug 2024 10:27 PM
It's not a fix, but a quicker workaround if netflix isn't loading (rather than rebooting sky box) is to open any other streaming service and then opening netflix.
Works everytime.
Message posted on 19 Aug 2024 06:09 AM
@Budda08 wrote:It's not a fix, but a quicker workaround if netflix isn't loading (rather than rebooting sky box) is to open any other streaming service and then opening netflix.
Works everytime.
Some other people have had luck with that too but some not. It's weird.
Message posted on 19 Aug 2024 10:51 AM
Re: 2nd Q box issue
Got it sorted, finally got through to customer service and they talked me through doing an app refresh. Sttings update then app refresh worked. I had to sign into all of my apps again but at least it worked.
Message posted on 19 Aug 2024 04:35 PM
Netflix not starting up on the Sky mini box
Message posted on 19 Aug 2024 04:47 PM
Re: Netflix not starting up on the Sky mini box
Red spinning circle?
Message posted on 19 Aug 2024 04:52 PM
Yep. Red circle going round and round and round etc etc
Message posted on 19 Aug 2024 04:59 PM
I've moved your post into a large thread discussing this issue. Please see the post (number 2) currently showing as the answer.
Message posted on 20 Aug 2024 09:07 PM
Re: NETFLIX ON SKY NOT WORKING
Hi my netflix in bith sky boxes will not work. It laods woth the red circle movikg thsts it. Happened now for over a week very frustrating tried everything
Message posted on 20 Aug 2024 09:47 PM
