Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 02 Aug 2024 10:48 AM
Re: Netflix: Red Spinning Circle on Launch
Is there any expected time for the issue being solved permanently?
Message posted on 02 Aug 2024 12:36 PM
@Mikanda1 wrote:Is there any expected time for the issue being solved permanently?
I'd expect an updated post, marked as the answer, from Sky when there is
Message posted on 02 Aug 2024 12:37 PM
Removing all devices online and then fully rebooting the Q box usually is a permanent fix.
Message posted on 02 Aug 2024 12:39 PM
I can imagine that whatever set of circumstances causes the issue can re-occur though.
Message posted on 02 Aug 2024 12:44 PM
Maybe, although if it is because of an expired authentication token (most likely?) then it should take a long time to come back up and hopefully has been resolved by the software update for the future.
Maybe 🙂
Message posted on 02 Aug 2024 08:00 PM
Cannot access Netflix
Message posted on 02 Aug 2024 08:07 PM
Re: Cannot access Netflix
@Migsy1 are you seeing a spinning red circle ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 Aug 2024 09:56 PM
Yes, it just keeps spinning round and round
Message posted on 02 Aug 2024 09:57 PM - last edited: 02 Aug 2024 10:19 PM
Hi @Migsy1
Are you seeing the rotating red circle?
If you are see the following thread.
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4428388#M602362
Message posted on 02 Aug 2024 11:48 PM
When I load Netflix up it just goes round in circles and loads and loads for hours and doesn't do anything, can you help?
Message posted on 03 Aug 2024 05:42 AM
Have you tried this:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4510468#M620067
Message posted on 03 Aug 2024 10:28 AM
Netflix through sky q not working .... death circle is all we get!
Message posted on 03 Aug 2024 12:11 PM
Netflix not working on 1 mini box
One mini box does not load Netflix. This has been ongoing for some time. Just spinning cicle on Netflix logo screen. How do I fix this?
Message posted on 03 Aug 2024 12:21 PM
Re: Netflix not working on 1 mini box
I've moved your post into this lengthy thread discussing this. For starters see post 2 currently showing as the answer.
Message posted on 03 Aug 2024 01:23 PM
Cannot load Netflix on sky q box
I'm unable to load Netflix on my sky q box, but it loads on the sky mini box and tablets. I signed out of one of the tablets, but it's still not loading. It's stuck on Netflix logo and loading sign.
