15
This discussion topic has been answered Discussion topic: Trouble switching on TV with Sky Stream
This message was authored by: AlyB4
Just got Sky Stream, so I turn my TV on using TV remote and then turn Sky puck on using Sky remote. TV comes on, but no Sky available. I have to turn the TV off and back on again (using TV remote) to get Sky on the screen. I've spoken to Sky and they have not managed to fix my problem. Anyone got any ideas.
Avatar for AlyB4
This message was authored by: AlyB4 Answer
Re: Trouble switching on TV with Sky Stream
  • I had paired my puck with the remote successfully. But I never held the stand by button down for a while and that seems to work with switching the TV off and it works to switch it back on with Sky on the screen.
This message was authored by: Skull+Treaty
@AlyB4
Does it work if you turn the Stream device on first, then when the light is on, turn the TV on?
Avatar for AlyB4
Yes it still happens,  either way as I tried both. The sky employee said I should turn the TV on first, so that’s what I tend to do.
This message was authored by: nmbailey
With my LG TVs I just press the Home (green) button on the Stream remote and the TV and the box both wake up. Takes about 10 seconds
Avatar for AlyB4
Thanks for the suggestion,  just tried that and it's not working for me.
What are your CEC setting on your Puck and TV?
@AlyB4
What TV do you you have connected to Stream?
Avatar for AlyB4
I'm not sure,  I've never heard of the CEC setting. Would you be able to give me some more information
Avatar for AlyB4
I have an LG television
How is it connected? I use the eArc HDMI port to connect my LG C4. The Stream home button launches Stream, TV and Sonos Beam in that order, takes around ten seconds
@AlyB4 @nmbailey
Mine is a similar arrangement:
Stream, Apple TV, BDP ---> AVR
AVR ---> LG G3 display
Using the Stream remote, turning on will activate the TV and AVR. I have terrible handshake issues, its a widely known LG issue - really grinds my gears!
Avatar for AlyB4
@Skull+Treaty
@nmbailey
I just looked and it's plugged into the HDMI eARC already.
I think I'll have to contact Sky again!
@AlyB4 wrote:
@Skull+Treaty
@nmbailey
@AlyB4
Using Stream, with the device on, go to Home, then Settings, then Start up (I think that's what it's called), then scroll down to HDMI control, is that on or off?
Avatar for AlyB4
The HDMI control is on
LG call CEC ... SIMPLINK under HDMI settings😉
Have you successfully paired your Puck remote and TV ... does volume UP/DOWN work ... does a long press on the Puck's standby button activate standby on Puck and TV?
