This discussion topic has been answered Discussion topic: Problems with missing tiles and the UI lagging
Message posted on ‎27 Aug 2026 02:30 PM
Re: Sky stream morning regular puck reboot
@JackieZas you mention "WiFi" dropouts not solved by MAX, do you actually mean you lose interent connection or is it a WiFi coverage issue in your home?
Regardless of the above as you say you are connected by ethernet then home wireless issues are not a factor unless of course you have the puck WiFi set to ON which means if that connection has been set up previously it will default to even with a cable plugged in.
Turn WiFi off in the settings and see what happens.
You need to clarify what exactly is dropping put.
Message posted on ‎27 Aug 2026 05:31 PM
Thanks Martin. The 1st issue is the puck and switch on in the morning. The 2nd is the Wi-Fi drops out for a few seconds on video calls even tho the computer is close to the router and uses Wi-Fi.
ive change the puck Wi-Fi to off so we'll see if it works tomorrow.! Many thanks Jackie
Message posted on ‎27 Aug 2026 06:19 PM
@JackieZas wrote:Thanks Martin. The 1st issue is the puck and switch on in the morning. The 2nd is the Wi-Fi drops out for a few seconds on video calls even tho the computer is close to the router and uses Wi-Fi.
It sounds like you conflating two separate things here. It seems you 1. have an issue with your sky puck and 2. feel there's an issue with WiFi to your hub connection. The puck is connected via Ethernet so that's a separate thing. You haven't stated 'why' you have to reboot the puck. Is it just not coming out of standby mode or something?
You mention WiFi drop outs on video calls only so everything else on the internet works ok? It could be that it's the person you are video calling that is having the drop outs and not you is what I'm thinking.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.052.00P; UI 3.268.3; Platform Version 8.4p52s1 | Sky Broadband Superfast
Message posted on ‎28 Aug 2026 01:10 AM
Re: Problems with missing tiles and the UI lagging
With all due respect, we're all paying for this service and right now I'm switching on my sky puck and waiting 2 minutes before anything loads because it can't find the internet , then when I scroll, it's mostly missing so I wait longer. This "read the answer and wait for your update" is not acceptable. Fix your "shizzle" because you won't delay a price increase if you want one
Message posted on ‎28 Aug 2026 11:32 AM
Thanks for the info.
Unfortunately the switching off WiFi on the puck hadn't changed anything today, so yet another reboot this morning .
Re WiFi dropping out, it's not the other party as its happened with different peoples video calls. Constant freezing of the call.
I understand from previous responses it's to do particularly with apple computers. I can only work from my phones hot spot.. which is apple too. So using up my data too.
Im just unsure what to do now and am considering cancelling my contract even with penalty.
Message posted on ‎28 Aug 2026 06:10 PM
@JackieZas wrote:Thanks for the info.
The WiFi issue is really a separate topic to this thread. All I'll say is that my MacBook Pro works seamlessly for video calls etc. with Sky Broadband through the WiFi on my Sky Hub and currently I only have Superfast and not full fibre. You could try connecting your Apple computer to the sky hub via Ethernet to see if that makes a difference. Otherwise all I can think is some kind of conflict on your network.
Message posted on ‎28 Aug 2026 09:05 PM
Sky Glass Gen 1 Home Screen blank Boxes
Message posted on ‎28 Aug 2026 09:07 PM
Pictures on Sky Glass homepage tiles still missing
There are still random blank blue tiles on the Homepage.
Message posted on ‎28 Aug 2026 09:52 PM
Re: Sky Glass Gen 1 Home Screen blank Boxes
Supposed to be fixed in UI 3.268.3 when it's rolled out.
OS 1.3
Build QS040.040.00P
UI 3.268.3
Platform 8.4p40s1
Hardware IP061-ef
TV Sony A95K
AV Sony HT-A9
Broadband Hyperoptic FTTP 1.0Gbps
Ethernet to Sky Stream
Message posted on ‎30 Aug 2026 01:57 PM
Puck doesn’t always work
Sky puck isn't working properly - lots of blank areas when looking at apps and not always working at all when we first turn TV on
Message posted on ‎30 Aug 2026 02:17 PM
Re: Puck doesn’t always work
@Susan771 wrote:Sky puck isn't working properly - lots of blank areas when looking at apps and not always working at all when we first turn TV on
There's currently a bad software update on many Sky Stream pucks causing this issue - this is in the process of being fixed and a new software version is being pushed out in batches. You'll need to wait for your puck to receive it as you cannot force an update.
Message posted on ‎30 Aug 2026 08:43 PM
missing tiles
Why does sky keep closing the missing tiles post
Not really an answer
Not been fixed
Been months now
Message posted on ‎01 Sep 2026 05:58 AM
My UI version appears to have been updated overnight. All the tiles are now populating for me!
I was on 3.268.1 and the version has now been updated to 3.291.1
Sky Stream Ultimate TV / Sky Cinema
Message posted on ‎01 Sep 2026 07:29 AM
Mine too, thank God after weeks of missing tiles and sluggish movement thanks Sky
Message posted on ‎01 Sep 2026 07:34 AM - last edited: ‎01 Sep 2026 07:36 AM
@mancsmark Good news at last. The question I have is why it takes Sky so long to fix a very obvious problem that a lot of people have suffered from for months. 🤷
OS 1.3
Build QS040.040.00P
UI 3.268.3
Platform 8.4p40s1
Hardware IP061-ef
TV Sony A95K
AV Sony HT-A9
