85
This discussion topic has been answered Discussion topic: SkyQ Blue Screen
Re: Sky q box freezes the blue screen
@Dave19634
As you can see your post has been moved into a thread discussing this. Sky are aware of it.
This message was authored by: Siblin
Re: SkyQ Blue Screen
+1 on this issue.  I'd already figured out it was something to do with regionalised or custom ads.  Probably something like MPEG-TS signals, switching over to custom ads and crashing the decoder.
i just turned off personalised TV ads in my sky account settings, just managed to watch an episode of the chase on challenge without it crashing during the break.  Will see how this progresses.
the most distressing bit about this is learning that personalised ads exists, having wondered why for the past few weeks I've seen so many adverts for funeral care!
You'll still see plenty of those adverts, it's nothing personal. The funeral industry are among the top spenders on UK TV advertising!
This message was authored by: PastSellByDate
How do you turn off personalised adds o n a Sky Q box. Will it help it must have disadvantages
This message was authored by: Liamedward
Re: SkyQ blue screen
I fixed this by downloading the newest software update, took 10 mins
It's done within your account in sky.com.  I found it reduced the frequency of issues but didn't eliminate them.   I was still rebooting my box every couple of hours if watching a channel with smart adverts.
the downsides are you'll be watching adverts that may be less relevant to you.
This message was authored by: props77
To turn off personalised ads (Sky AdSmart) on your Sky Q box, you must change your privacy choices online via your Sky account dashboard, as this setting cannot be toggled directly through the TV remote settings. [1]
Step-by-Step Guide
  1. Log in to your official account on the Sky Personalisation Portal.
  2. Scroll down the page until you locate the section labeled Tailored TV Advertising.
  3. Toggle the switch to OFF (or uncheck the box) to opt out.
  4. Wait for the system to sync. It can take up to 24 hours for the updated privacy cache to push through to your physical Sky Q box. [1, 2, 3]
This message was authored by: Chloe-W22 Answer
Posted by a Sky employee
Good morning all,
I'm sorry to see you were having a problem with Sky Q over the weekend. I just wanted to jump in to confirm Sky are aware of the issue and continue to investigate. In the meantime a full reboot at the power of your Q box will resolve this temporarily until a permanent fix is put in place.
Thanks or reporting this via the Sky Community 💪
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by: Hannah257
Hi,
Ive been having this issue probably the last 5 days- almost relieved to know its not just me. However I have just ordered a new Sky Q box as the tv "fixes" said if it didn't improve that's what was needed. Just wondering if I am going to need a new box or if I should cancel but this is so annoying! Just want to sit and relax but sometimes I literally have to get up every half an hour to reboot everything!
Is it fixed yet or isthereva likely solution time. In the meantime I am avoiding using the affected channels
@PastSellByDate
Sky won't give an estimated time for a fix. I'm sure @Chloe-W22 or someone else will update the thread in due course.
This message was authored by: Ken5244
I updated my sky to the latest update but it still happens, it has just done it again!!!
@Ken5244 this is a known problem have a look at the post 4 above yours by @Chloe-W22 that is marked as the answer
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Jennhatton
Blue screen
For the last four days every now and then sky will freeze and all we get is a blue screen we have to unplug and reboot now I can't access any apps on sky no home page and keeps saying it looks like you don't have internet connection even though I have  I've tried rebooting the box and router just don't know what's going on
This message was authored by: Nikola11
Re: Blue screen
We are the same but only on my bedroom not on my main box
Answered - Go to Answer
