This discussion topic has been answered Discussion topic: SkyQ Blue Screen
Message posted on 30 Jul 2026 07:31 PM
SkyQ has Blue screen and no sound on all channels. Rebooted it, but it's happened again!
Message posted on 03 Aug 2026 11:18 AM
Good morning all,
I'm sorry to see you were having a problem with Sky Q over the weekend. I just wanted to jump in to confirm Sky are aware of the issue and continue to investigate. In the meantime a full reboot at the power of your Q box will resolve this temporarily until a permanent fix is put in place.
Thanks or reporting this via the Sky Community 💪
Message posted on 22 Jul 2024 10:29 AM
My tv screen is locked showing a blue screen and cannot select any channels
This happened last Thursday and haven't had any sky channels since then
Message posted on 22 Jul 2024 10:49 AM
Re: My tv screen is locked showing a blue screen and cannot select any channels
Which Sky System do you have?
2. Sky Q (Sky Q Forum)
3. Sky Glass & Live (Sky Glass & Live)
4. Sky Stream (Sky Stream)
Message posted on 22 Jul 2024 11:49 AM - last edited: 22 Jul 2024 11:50 AM
@David7906 wrote:This happened last Thursday and haven't had any sky channels since then
You specifically say your "TV screen". Do you know if it's an issue with your TV or Sky device?
If you're able, try connecting your Sky device into another TV and see if this fixes the issue. If it does, it's an issue with your TV and you will need to contact the manufacturer for this.
If this doesn't work, try restarting your device:
- Unplug your Sky device from the main plug (the one going into the plug socket on your wall).
- Wait at least 4 minutes.
- Turn on your device
- Wait for the system to load fully
- Check channel 998 (Sky+HD, Sky Q, etc.) / channel 501 (Sky Glass/Stream)
If you see picture and hear sound, the issue is fixed.
Message posted on 30 Jul 2026 07:52 PM
Re: SkyQ Blue Screen
We've had the same thing happen twice today, we've switched off on the wall, switched back on and it's been ok again but this must be a glitch or something in weather maybe?
Message posted on 30 Jul 2026 08:06 PM
SkyQ blue screen
How do I resolve skyq blue screen?
Message posted on 30 Jul 2026 08:11 PM
Re: SkyQ blue screen
@Sandi.T is there any message on the blue screen and is this the main box or mini box ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Same here at 20:00
no on/offs working
Live TV not working
Recording in the device not Working
Message posted on 30 Jul 2026 08:17 PM
Main skyq box
Blue screen no sound all channels
Sky scan says all OK.
Reboot works for a few minutes the blue screen again
Message posted on 30 Jul 2026 08:18 PM
No error messages
Message posted on 30 Jul 2026 08:29 PM
Blue screen
Blue screen on all Channels, no sound been like this for half an hour at least maybe longer. WiFi is working. Turned it off and turned it back on still the same
Message posted on 30 Jul 2026 08:40 PM
SkyQ blue screen
Skyq blue screen seems to have resolved itself, after yet another reboot switch off. Fingers crossed it keeps working this time!!!
Thank you for replies.
Message posted on 30 Jul 2026 10:26 PM
Called earlier regarding blue screen was fixed happening again
Can access home page black upper left able to select programme using remote once selected blue screen no programme . Called earlier today did a reset unplugging sky box worked fine until 10 pm same thing happened . I unplugged sky as I did earlier today everything came back on but cannot keep doing this as means to watch tv there clearly is a more underlining issue that needs investigating
Message posted on 30 Jul 2026 10:28 PM
Blue screen
Message posted on 30 Jul 2026 10:30 PM
I've had the same issue all evening. Keep switching box off waiting a minute then switching on. That works for around 30 mins then it happens again.
