22
This discussion topic has been answered Discussion topic: Now 70's
This message was authored by: country.girl
Now 70's
Trying to watch Now 70's on my Sky Q box , but there's a message on my tv saying 'this channel is currently affected by a problem with your satellite signal' for help press '? ' when I press ? There's option's about weather/trees/building work. It also says is it just 1 channel? Check other channels see if iys a satellite issue? If its only 1 channel, it's a broadcaster issue, so try again later. Now 80's isn't there either. I've been trying since Thursday.  Just wondering if channel's moved again or gone altogether? TIA
This message was authored by: xenon81 Answer
Re: Now 70's
@country.girl wrote:
Thanks, yes I know NOW 70's was taken off 'normal' tv, then you could re-tune the box + watch it thru Manual tuning. this is where i was watching it previously.,
We're finally getting there! In that case you just need to re-add it as some of the technical details have changed recently.
The new details are:
Frequency: 11.081
Polarisation: H
Symbol Rate: 23.0
FEC:2/3
Standard: DVB-S2
Modulation: 8PSK
Re: Now 70's
Now 70s and 80s are both working here. It sounds like your dish may be slightly out of alignment as that can cause you to lose channels (often just a few). Other channels broadcast on the same frequency include Blaze (164) and Rewind TV (190), are they working?
Re: Now 70's
@country.girl
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Re: Now 70's
They have changed channels, see here: https://helpforum.sky.com/t5/What-s-On/Changes-to-the-Sky-TV-Guide-July-2024/td-p/4678819
Re: Now 70's
That's just an channel number change. It won't be responsible for a "no satellite signal" message.
Re: Now 70's
Sure, assuming OP is selecting the right channel numbers... (seems like could be alignment issues)
Re: Now 70's
There is nothing on the previous numbers so entering them would result in a channel unavailable message rather than no satellite signal.
Avatar for country.girl
Level 2 icon
Re: Now 70's
Thank you for your reply.
Blaze is OK.
Rewind 190 isn't on my channel list.
Level 2 icon
Re: Now 70's
Good afternoon
Thanks for replying to my question. Yes I saw the list when searching for n answer, but in the list NOW 70s moves from 361 to 355 on satellite only, but i dont have either channels on my tv list, when NOW 70 moved from normal TV I'd to tune my tv in to receive the channel, but there's no 'number' for me to re-tune my Sky box.
Level 2 icon
Re: Now 70's
I searched for NOW  70's and on the Sky page, it says that NOW  70's has moved from 355 to 361. but the channel's not been on 'normal TV for a while, since it got taken off due to a licence fee?   then I searched again + found the frequency that NOW 70's had moved to, so I tuned my TV into the frequency given, but it's saying there are no channels on that frequency.
I'm desperate to get NOW 70's back, cause when I'm cleaning I listen to that channel!! 🙂
Re: Now 70's
Are you in the UK or Ireland? When was Now 70s last working? It's particularly odd that you can get Blaze but other channels on the same transponder aren't working, or are missing.
This message was authored by: Doc5907
Re: Has the 'Now 70's' music channel been turnd off?
I then I searched again + found the frequency that NOW 70's had moved to, so I tuned my TV into the frequency given, but it's saying there are no channels on that frequency.
@country.girl  NOW 70s is on ch355 on my Sky Q so have you tried a reboot suggested in the post above yours.
Sky Q 1TB UHD
LG TV
Sky Mobile
Re: Now 70's
@country.girl  Your other post tagged on the end of another thread has been removed, please don't cross post as you have replies already within this thread.
Level 2 icon
Re: Now 70's
@xenon81
I'm in Ireland + NOW 70's went opff around the time of the 1st post in this thread. It's working before then.
No channel 355 on my sky q box it goes from 353 MTV 80s to 401 SkySpMainEvHD
The sky box has been re booted several times
Thankks for all the  suggestions
Re: Now 70's
@xenon81
@country.girl
Ah, didn't realise it was all different in Ireland. Sorry I can't help.
Sky Q 1TB UHD
LG TV
Sky Mobile
Answered - Go to Answer
