Discussion topic: Sky Q dish receiver bracket corroded / snapped - no satellite signal
This message was authored by: Hougany
The bracket holding the receiver has completely rusted through and broken resulting in no satellite signal.  The dish clearly needs replacing and I have a sky engineer booked for the 30th August. However, I have read elsewhere on this site that I might be charged by sky for a replacement as I 'own' the dish. Is this true, and if so at what cost?
Thanks.
Re: Sky Q dish receiver bracket corroded / snapped - no satellite signal
You shouldn't be charged in these circumstances.
Also you can also ask Sky for a credit once it's fixed back to point of reporting the fault.
Thanks.
hi @Hougany
Assuming you have SKY Q, then it is very likely to be replaced free of charge.
I think they are only likely to charge where the dish is rusty but still working  & the customer wants it replacing raher than it needs it replacing.
BTW I think the standard fee for dish replacement/moves etc is around £65
Avatar for Hougany
Thanks PandJ2020, that's what I would have expected so good to get some views 😊
Avatar for Hougany
Thanks Nige99, that backs up what I thought, I will post back after the engineer calls.
