22
Discussion topic: Now 70's
This message was authored by xenon81 This message was authored by: xenon81
Re: Now 70's
@country.girl wrote:
@xenon81
I'm in Ireland + NOW 70's went opff around the time of the 1st post in this thread. It's working before then.
No channel 355 on my sky q box it goes from 353 MTV 80s to 401 SkySpMainEvHD
The sky box has been re booted several times
Thankks for all the  suggestions
The Now music channels aren't available in Ireland and haven't been for several years. If you still had Now 70s until recently then it was a mistake which has now been corrected.
As you can see below the only music channels available in Ireland are the MTV channels.
https://www.mediamole.co.uk/entertainment/broadcasting/information/sky-ireland-full-channels-list-ep...
country.girl
This message was authored by country.girl This message was authored by: country.girl
Re: Now 70's
Thanks, yes I know NOW 70's was taken off 'normal' tv, then you could re-tune the box + watch it thru Manual tuning. this is where i was watching it previously.,
This message was authored by Anonymous This message was authored by: Anonymous
Re: Now 70's
Don't know if it'll help but the frequencies are given at https://www.lyngsat.com/packages/Sky-UK.html for manual tuning.
Edit: just search for Now 70's
This message was authored by xenon81 This message was authored by: xenon81 Answer
Re: Now 70's
We're finally getting there! In that case you just need to re-add it as some of the technical details have changed recently.
The new details are:
Frequency: 11.081
Polarisation: H
Symbol Rate: 23.0
FEC:2/3
Standard: DVB-S2
Modulation: 8PSK
Re: Now 70's
Frequency: 11.081
Polarisation: H
Symbol Rate: 23.0
FEC:2/3
Standard: DVB-S2
Modulation: 8PSK
11082 frequency according to Lyngsat.
Re: Now 70's
Frequency: 11.081
Polarisation: H
Symbol Rate: 23.0
FEC:2/3
Standard: DVB-S2
Modulation: 8PSK
I use https://www.digitalbitrate.com/dtv.php?mux=11081&liste=1&live=69&lang=en which has 11.081 but either will work fine.
country.girl
Re: Now 70's
Hi, thanks for the table.. I used the info on it,  but again 'no channel found'
Thanks for everyone's help.
Re: Now 70's
Make sure you're entering all the tuning details correctly, and remember the Standard and Modulation also need changing. As you can receive channels on that transponder such as Blaze there is no reason you can't manually tune it in, as long as the details are entered correctly.
