2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Beaupoet
Re: Netflix: Red Spinning Circle on Launch
This would be acceptable if you had to do it once and then that was it. But I have to do this almost every day. That is not acceptable service from Sky or  Netflix.
Re: Netflix app issue
@elizabethlyson
In that case your post has been moved into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
This message was authored by: Cazziekw
Netflix won't work. I just get a black screen with Netflix across the middle and a rolling ciircle
My netflix won't load. I'm getting a black screen with Netflix written across the middle and a rolling circle underneath. It looks like it's trying to load but doesn't go any further.
I've tried to sign in on my laptop and it says it doesn't recognise my email address with an account but my sky app says netflix is included in my package and it has worked until recently.
Re: Netflix won't work. I just get a black screen with Netflix across the middle and a rolling ciirc
@Cazziekw
I've moved your post into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
Thank you.
This message was authored by: Sean6554
Hi I can't get Netflix to load it stop at Netflix with a red spinning circle underneath
@Sean6554
This message was authored by: Stephen+gre
Netflix hasn't loaded for 2 week
Why am I paying for netflix? Hasn't landed up in two week
This message was authored by: Louise+Allman
Netflix will not load on skyQ
I have reset the router and SkyQ box but I can still not get the Netflix app to load, its been weeks now.
Re: Netflix will not load on skyQ
@Louise+Allman
You were asked this question as you said you have tried everything but you didn't answer what you had actually tried ?
Re: Netflix hasn't loaded for 2 week
@Stephen+gre
Are you seeing the red spinning circle ?
This message was authored by: Graham111
Re: Netflix Won't Load / Spinning Circle
I was unable to access Netflix on one of my mini boxes. The red circle was endlessly going around. I carried out a reset and now have not got any apps on this mini box. Please advise.
It's all working now.
This message was authored by: G-Man99
Come on sky. Get this fixed it has been goind on long enough
if i power cycle the sky box then nrtflix will load after a short period of the spinning red circle. Exiting netflix and re-entering it again loads straight into netflix without reloading the red circle suggesting to me that the netflix logon details/veeification have been cached. Loading another app such as disney+ or prime video means that a subsequent load of netflix results in the constant spinning red circle. This also suggests to me that the other apps are overwriting some of the netflix cacheched information. This has become so annoying that i have purchased a remote control power socket to allow me to easily power cycle the sky box if i want to watch netflix. This is not to the standards i expect from a premium service like sky
@G-Man99
Did you follow the advice as posted in the post here marked as the answer ?
Locked
Answered - Go to Answer
