2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Edg1888
Re: Netflix often not working on SkyQ
Thank you, fed up of trawling looking for answers then someone mentioned your response. Worked a treat. Maybe sky should pin your solution at the top of the thread they have to save time for everyone. And personally I think you should get at least 6 months for free from them @Sam9999
It is marked as the Answer post in the main Netflix spinnny circle thread, posted by Chloe. (Edit: oh has this thread been merged into that one now?)
albeit Sam wasn't given the credit properly as someone else was quoted.
This message was authored by: G-Man99
Re: Netflix: Red Spinning Circle on Launch
OK I have now tried the method of signing out of the sky box using the Netflix website in a browser as referred to in the answer and that seems to have worked so will monitor the situation.
I'd been reading through the main thread and someone had stated that the guys response worked. I clicked his name she had tagged and it took me to his (maybe hers) post. I may have crossed threads in my search.
This message was authored by: AS67
I cannot watch netflix on the tv
Thw netflix app will not open its just goes round and round.
i can watch it on my phone
Re: I cannot watch netflix on the tv
@AS67
In that case your post has been moved into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
This message was authored by: Stephen+gre
Re: Netflix hasn't loaded for 2 week
Yes getting the red circle
This message was authored by: Justin28
Unable to access netflix on sky q box
Unable to access netflix on sky q box. Works fine on other non sky q box. When you go to netflix app you see the Netflix name then the red wheel just goes round and round
This message was authored by: pmd001
Issue with the Netflix app not loading
The Netflix app often doesn't load and the load circle just keeps spinning. Can you please help!
Re: Unable to access netflix on sky q box
hi @Justin28
 I have moved your post to the main discussion on this.
Please see the post currently marked as an answer that hopefully will help
Edit ; @pmd001  likewise
@Stephen+gre
Then give this a try:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4694387/highlight/true#...
This message was authored by: magictigger1
Unable to access Netflix on Sky Q box
I have tried to access Netflix app on Sky Q box and it doesnt load - just red circle spinning around.
Ive refreshed the apps - still not working.
Any ideas?
Re: Unable to access Netflix on Sky Q box
Any ideas?
hi @magictigger1
Still getting the same problem so resetting Netflix on the web does not work either. I Jane not tried resetting the sky settings but I should not have to clear and reset everything on sky to fix this. Seems like sky still cannot resolve this. May need to change supplier (after being a customer for 23 years!!).
Locked
Answered - Go to Answer
