13 Jul 2024 12:05 PM
I've spoken to sky they are aware of the issue and Netflix are trying to solve it now
13 Jul 2024 12:18 PM
13 Jul 2024 12:21 PM
Posted by a Superuser, not a Sky employee. Find out moreLikewise @Stuart6641
Your post has been merged with a thread on the Netflix issue some customers are experiencing. See the post currently marked as the answer.
13 Jul 2024 12:28 PM
Hi. There was an earlier answer (from Sam999 I believe) on this that seems to work for most of us. I recommend you try signing in to Netflix thru a laptop or mobile Ie not Sky then try the following
If you cannot log into Netflix through SkyQ box:
1 - Log into Netflix via a web browser.
2 - Highlight your profile picture (Top right corner).
3 - Click on Account.
4 - Under the Security and Privacy option, click on Manage access and devices.
5 - Select the device name: (Sky UK Set-top box).
6 - Click on the "Sign out" option on the Sky UK Set-top box.
7 - Go to your SkyQ box and perform a complete power cycle on the SkyQ box (not just on standby mode)
8 - Launch the Netflix app on your SkyQ box.
If you manage to log into Netflix on the SkyQ box:
1 - While you are in your Netflix profile on the SkyQ box, scroll down and on the right hand corner and click on/select the 'Get Help'option.
2 - Sign out of Netflix.
3 - Sign back into Netflix (with your email address and password for your Sky Subcription if you don't have a separate subscription for Netflix). Alternatively, sign in with your Netflix credentials if you have a separate Netflix subscription.
4 - Power cycle (on and off) your SkyQ box. Make sure the power is completely out (not just on standy mode)
13 Jul 2024 12:42 PM
Yes, its the unending circle.
13 Jul 2024 12:50 PM
We have had this now for months. It almost definitely doesn't load but once in every 15 attempts it might. Ridiculous. Why can't this be fixed? It's clearly a major problem.
13 Jul 2024 12:52 PM
just set up sky broadband a few hours ago. cant get apps auch as netflix as they wont download
13 Jul 2024 01:09 PM
13 Jul 2024 02:04 PM
My son has a sky mini box in his room and Netflix takes ages to load sometimes over an hour before Netflix works. He has good connection with the Wi-Fi.
13 Jul 2024 02:23 PM
Posted by a Superuser, not a Sky employee. Find out moreIs he / are you seeing a red spinning circle?
This is still an issue and the workaround is a farce sometimes works othertimes doesnt , plus i dont want to have to take 10 minutes rebooting sky everytime i want to watch netflix .
So many issues like this with sky , we pay a premium for this service sort it out sky and think of your customers for a change
13 Jul 2024 02:25 PM
Netflix not working
Netflix not working
13 Jul 2024 02:33 PM
Yes, the circle spins for ages and ages and just won't load
13 Jul 2024 02:38 PM
13 Jul 2024 02:41 PM
Posted by a Superuser, not a Sky employee. Find out moreI've merged your post into a thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2).
