Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 13 Jul 2024 10:10 AM
Re: Netflix: Red Spinning Circle on Launch
Glad it helped. Apologies but I don't know who originally posted this solution but I'm also grateful to them.
Message posted on 13 Jul 2024 10:13 AM
@bmwgem wrote:This is still an issue!!
I've tried all the tips in the previous answers but still it's not working!Think it's time to cancel with Sky and go direct
That will not make the Netflix app on your Q box work anymore than paying Sky direct (besides costing more than through Sky).
If the 'remove the device from your Netflix account' trick doesn't work (I can't recall it not working for someone) then if you have a Smart TV or an Amazon Firestick for instance, simply use them. You generally get a better quality picture and sound anyway.
Message posted on 13 Jul 2024 10:14 AM
Message posted on 13 Jul 2024 10:24 AM
Netflix not responding
Netflix not responding on my mini box.That's all I'm having is the red circle going round and round but it's not going anywhere
Message posted on 13 Jul 2024 10:53 AM
Re: Netflix not responding
Message posted on 13 Jul 2024 11:06 AM
Hi. There was an earlier answer (from Sam999 I believe) on this that seems to work for most of us. I recommend you try signing in to Netflix thru a laptop or mobile Ie not Sky then try the following
If you cannot log into Netflix through SkyQ box:
1 - Log into Netflix via a web browser.
2 - Highlight your profile picture (Top right corner).
3 - Click on Account.
4 - Under the Security and Privacy option, click on Manage access and devices.
5 - Select the device name: (Sky UK Set-top box).
6 - Click on the "Sign out" option on the Sky UK Set-top box.
7 - Go to your SkyQ box and perform a complete power cycle on the SkyQ box (not just on standby mode)
8 - Launch the Netflix app on your SkyQ box.
If you manage to log into Netflix on the SkyQ box:
1 - While you are in your Netflix profile on the SkyQ box, scroll down and on the right hand corner and click on/select the 'Get Help'option.
2 - Sign out of Netflix.
3 - Sign back into Netflix (with your email address and password for your Sky Subcription if you don't have a separate subscription for Netflix). Alternatively, sign in with your Netflix credentials if you have a separate Netflix subscription.
4 - Power cycle (on and off) your SkyQ box. Make sure the power is completely out (not just on standy mode)
Message posted on 13 Jul 2024 11:20 AM
Netflix on skyq wont load works on all over devices and tvs tried retarting skyq box several times a
Netflix not loading on main skyq box tried resetting box and refreshing app on hidden menu works on all other devices and tvs
Message posted on 13 Jul 2024 11:22 AM
Kashif
My netflix is not working over a week
I have tried different options including pressing back buttons and play buttons etc without joy
Please assist
Message posted on 13 Jul 2024 11:26 AM
Re: Kashif
Are you seeing a red spinning circle at launch by any chance?
Message posted on 13 Jul 2024 11:28 AM
Re: Netflix on skyq wont load works on all over devices and tvs tried retarting skyq box several tim
Are you seeing a red spinning circle?
Message posted on 13 Jul 2024 11:40 AM
Netflix will not load - red circle going round and round
Message posted on 13 Jul 2024 11:51 AM
Re: Kashif
Your post has been merged with a thread on the Netflix issue some customers are experiencing. See the post currently marked as the answer.
Message posted on 13 Jul 2024 11:55 AM
Netflix not working red circle spinning round
Netflix isn't working just a red circle spinning trying to load we've done a system update still nothing
Message posted on 13 Jul 2024 11:59 AM
Re: Netflix not working red circle spinning round
Mines the same. Skyqmini. Tried everything
Message posted on 13 Jul 2024 12:03 PM
Your posts have been merged with a thread on the Netflix issue some customers are experiencing. See the post currently marked as the answer.
