Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 12 Jul 2024 08:25 PM
Re: Netflix: Red Spinning Circle on Launch
Just tried logging out via web browser and it worked straight away. Thanks 👍🏻
Message posted on 12 Jul 2024 08:34 PM
Netflix on second box upstairs not loading
Net flux on second box upstairs not loading
Message posted on 12 Jul 2024 09:18 PM
Netflix
Netflix doesn't work on multiplayer
Message posted on 12 Jul 2024 09:46 PM
I have carried out the procedure of signing out of Netflix on SkyQ using a web browser. Then rebooted Sky Q and it worked!
Message posted on 12 Jul 2024 09:53 PM
Netflix not working on minibox
For the last couple of months Netflix will not work on our minibox. It works fine downstairs, all the connections are good and no issues, but it will not connect upstairs, it's just buffering.
I have tried rebooting everything but nothing is working, works fine on the main box.
any suggestions?
Message posted on 12 Jul 2024 10:07 PM
Netflix scrolling
It worked for me!
Message posted on 12 Jul 2024 10:56 PM
Can’t get onto Netflix on sky
Using home button the App on the left side. Clicking Netflix, just get the swirling wheel of doom and Netflix won't load. Fine through the smart TV however
Message posted on 13 Jul 2024 07:46 AM
The only way I can get Netflix to load is by turning Sky box off at the wall, waiting a minute and then rebooting. Netflix then works for a couple of days before the red circle returns, then I have to repeat procedure. Beginning to think it's all too much hassle. No problem with any other streaming app so surely Sky should be able to fix this.
Message posted on 13 Jul 2024 08:08 AM
Hi. have you tried signing in to Netflix thru a laptop or mobile Ie not Sky then following the below? It's worked for me (and some others here) for a lot longer
Sign Out of device through a Web Browser:
- Log into Netflix via the web browser.
- Highlight your profile picture (Top right corner).
- Click on Account.
- Under the Security and Privacy option, click on 'Manage access and devices'.
- Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
- Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
- Sign out of Neflix on the Q box, start it up, press left and go to the help section to sign out.
- Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
- Go to your SkyQ box and launch the Netflix app on your SkyQ box.
Message posted on 13 Jul 2024 09:01 AM
@Pg666 wrote:Sign Out of device through a Web Browser:
- Click on Account.
Passed the above on to the Mother in Law who was having the same issue and it appears to work for then so far.
Many thanks to whoever posted it first 👍🏻
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 13 Jul 2024 09:22 AM
Hi @stereohaven You will find these instructions in the post marked as the answer, just open up the form.
Message posted on 13 Jul 2024 09:26 AM
This is still an issue!!
I've tried all the tips in the previous answers but still it's not working!
Think it's time to cancel with Sky and go direct
Message posted on 13 Jul 2024 09:43 AM
Message posted on 13 Jul 2024 09:50 AM
Netflix will not load on sky q. Tried restarting sky q box still not working. Hasn't worked for 5 days. All other apps working.
Message posted on 13 Jul 2024 09:51 AM
Hi. I recommend you try signing in to Netflix thru a laptop or mobile Ie not Sky then try the following
- Click on Account.
