34
This discussion topic has been answered Discussion topic: Sky Go on Consoles Log-in Problems
This message was authored by: Dan16
An unknown error has occurred. (ff2c5038)
anyone had this? Only just downloaded the app on a ps5 and getting this.
I 100% know it is the right username and password and I have deleted and re-downloaded. I have also turned on and off.
thanks
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: Kenny-J Answer
Re: Sky Go on Consoles Log-in Problems
Posted by a Sky employee
Hi all, we believe this issue is now resolved. Please stop the app and then relaunch,
Kenny J
This message was authored by: Monica+Graves
Re: Log In Error PS5
Having the exact same issue
This message was authored by: Bowwowwow
Sky Go app unknown error FF2c5038 PS4 and PS5
Hi there,
I've tried logging into the Sky Go app on both my PS4 and PS5 but keep getting the error message 'An unknown error has occurred FF2c5038'. It then just takes me back to email login.
I've tried my login on the app on my phone and tablet and all fine, and my details are definitely correct. I've removed / reinstalled the app, got the latest software and reset internet - any ideas what this error is and how to resolve it?
This message was authored by: Jim56
I am having the same issue. Can someone please advise a solution.
This message was authored by: drafter66
Re: Sky Go app unknown error FF2c5038 PS4 and PS5
I am having the exact same issue currently while trying to log in on my Xbox one
This message was authored by: Rosiejones95
Exactly same on PS5!!!
This message was authored by: btnn
Same issue on a PS4
This message was authored by: MissFrog
Same issue on XBOX Series X 😞 just downloaded app and definitely right password as username
This message was authored by: Jaack_x
Exact same issue
This message was authored by: James369damimfi
Exact same issue here too
This message was authored by: Marston
Same issue
This message was authored by: badgerz
Re: Sky go stopped working on Xbox series X
I have it on my playstation and p.c   bit gey an error  code ff2c5208 when I try and log in with xbox    I have whole home and sky go works on other devices
sky go error code ff2c5038
so last week sky go worked on my playstation 5 but not xbox series x.    now its not working on either    I get error code ff2c5038 on both devices.   I can still use sky go on my sons p.c in his room and ony phone.    every body is in the same house so its the same router so thats not the problem and I have sky whole house so thats not the problem. I've deleted and reinstaled both apps on both consoles(ps and xbox) and made sure both are updated so I can only put it down to the sky go app itself.    please help.   I'm disabled and watching sky in my room is a blessing as downstairs is a trek. so it not working 9n either of my consoles is really annoying.     thanks.    my package is sky glass and whole home with movies and entertainment.
This message was authored by: Dirtydools
Same here 😞 just got my ps5 too
This message was authored by: OnlyOn3Kanobi
Same issue here on Xbox One X.. called and made sure my subscriptions are okay which they are.
Answered - Go to Answer
