295
This discussion topic is read only This discussion topic has been answered Discussion topic: No Live Channels/Channels freezing on Glass & Stream 4/6
Locked
This message was authored by: Tim+Adams
Re: Sky glass please wait for programme to load
Hi @Khibbert
Unfortunately there is a service outage and Sky are working on it.
https://helpforum.sky.com/t5/Glass-Stream/No-Live-Channels-Channels-freezing-on-Glass-amp-Stream-4-6...
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
@Khibbert There is currently a known issue under investigation by sky, see the marked answer for latest update
Also see
https://www.sky.com/help/servicestatus
The above link may be inaccurate or may not yet show the latest information but should soon be updated to reflect current position
This message was authored by: bertierules
Re: No Live Channels/Channels freezing on Glass & Stream 4/6
Do we get a discount or something because this isn't our fault this has been going on for sometime
This message was authored by: Richrich
Programmes won’t load
Keeps saying programmes won't load and picture freezes and then stops loading,  not an issue with broadband as I've tested that and it's fine.
anyone got any ideas on how to solve this issue please?
This message was authored by: Shirl111
I am annoyed with my sky glass! live TV wont work, it keeps saying wait for programme to load. i have tried the turn it on/off trick, my wi-fi is working fine. Sky is not cheap! please FIX THIS SKY TEAM!! my apps work ok though
This message was authored by: Jporch316
Guys
a reboot or master reset is not going to fix this issue - it's a service wide issue
sky are aware as per their status page  - don't waste you time trying to call them
unfortunately the only fix is to wait ......
Confetti Ring
Avatar for GD1
Level 16 icon
@bertierules  We are customers here like you so we won't be able to tell you if you will or won't
Hi @bertierules
Unfortunately that's unknown, can only suggest you contact Sky once it's resolved.
Thanks,
Tim
@bertierules  That's something to take up with sky directly
This message was authored by: JayCamp
Sky Glass is Rubbish
Why is it that Sky Glass does not seem to be able to stream standard channels and shows the message "Please wait for your programme to load"?
I have c900mbps up and download speeds and so it is not the broadband. It seems to stream apps ok but television is a bloody nightmare.
This message was authored by: Khibbert
Ok. Cheers for your help
This message was authored by: Mal98
Re: No Live TV on Sky Stream Puck
Same issue here
Regards
Mal
This message was authored by: Angry+man+58
Sky glass
Why is sky glass so bad wish I'd never got it and stayed with sky Q I hope I'm not being charged for today 🤬😡🤬😡
Confetti Ring
Avatar for GD1
Level 16 icon
Re: Sky Glass is Rubbish
@JayCamp  There is an ongoing issue, so your post has been merged into the existing thread that is discussing this.
This message was authored by: micspics
Some news and sports channels are showing technical fault and are unavailable, other channels are gi
Picture and sound stutter, freeze and then show "technical fault. Please try later"
same fault on both Glass TV and puck in kitchen. CN watch same channel through Sky Go on my phone at the same location.
using the speed checker in Netflix my internet speed is around 72Mbps.
Locked
Answered - Go to Answer
