14
This discussion topic has been answered Discussion topic: Sky stream
This message was authored by: Scotty1956dex
Sky stream
Can you use sky stream with any broadband provider?
G J Scott
This message was authored by: Fothergill1 Answer
Re: Sky stream
@Scotty1956dex As you have already been advised by the previous post any BB provider can be used.  At my location I can't even get Sky BB.
The important thing is to make sure you BB is fast and stable enough.  Sky's minimum recommended BB speeds are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These are the speeds needed at the puck or Glass and not that being received by the router which can often be significantly different.
This message was authored by: Padam_Padam
Re: Sky stream
Yes, you can.
Re: Sky stream
HD = 25mbps
UHD = 30mbps
Re: Sky stream
@Scotty1956dex  almost any .... there are some ISPs that have issues😉
Re: Sky stream
@Exiled-in-HH @Who are the ISPs that have issues ?
Re: Sky stream
The ones that use non U.K. IP addresses and users of Persimmon BB  have reported issues, also those using 4G/5G mobile BB😉
Re: Sky stream
@Exiled-in-HH very niche then
Re: Sky stream
Yes but examples that not all are not not without issues😉
Re: Sky stream
@Exiled-in-HHDo you enjoy trolling ?
Re: Sky stream
No... do you ... we are just having a discussion ... that includes sharing opinions and being polite😉
Re: Sky stream
The altnet ISPs that use sets of non determined UK IPs is a problem with Sky Q also, its not unique to Sky Stream.
We can escalate an customer, if their ISP is using such ranges, to add or investigate.
4g and/or5g home broadband works fine with Sky Stream and Sky Q if its using one of the EE, O2 or Three etc recommended 4g and/or 5g home broadband packages and dedicated routers.
One router that works well for many is the Zyxel range like the NR5103e.
This message was authored by: marymcdonald240
Re: Sky stream
Set up sky streaming set up
Re: Sky stream
@marymcdonald240 do you have an actual question or problem that you need the community's help with or are you just making a statement?
Sky Stream, Sky Glass Air and former Sky Broadband customer
This message was authored by: Annpearmain1958
Re: Sky stream
It is frozen
Re: Sky stream
@Annpearmain1958 wrote:
It is frozen
Have you tried unplugging it for a couple of minutes?
