14
Discussion topic: Sky stream
This message was authored by Scotty1956dex This message was authored by: Scotty1956dex
Sky stream
Can you use sky stream with any broadband provider?
G J Scott
This message was authored by Fothergill1 This message was authored by: Fothergill1 Answer
Re: Sky stream
@Scotty1956dex As you have already been advised by the previous post any BB provider can be used.  At my location I can't even get Sky BB.
The important thing is to make sure you BB is fast and stable enough.  Sky's minimum recommended BB speeds are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These are the speeds needed at the puck or Glass and not that being received by the router which can often be significantly different.
If my post has solved your issue please mark as an "Answer"
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Sky stream
Yes, you can.
Re: Sky stream
HD = 25mbps
UHD = 30mbps
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Re: Sky stream
@Scotty1956dex  almost any .... there are some ISPs that have issues😉
Exiled in HH
This message was authored by Jason+Golding This message was authored by: Jason+Golding
Re: Sky stream
@Exiled-in-HH @Who are the ISPs that have issues ?
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
Amazon 4K Firestick
Re: Sky stream
The ones that use non U.K. IP addresses and users of Persimmon BB  have reported issues, also those using 4G/5G mobile BB😉
Exiled in HH
Re: Sky stream
@Exiled-in-HH very niche then
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
Amazon 4K Firestick
Re: Sky stream
Yes but examples that not all are not not without issues😉
Exiled in HH
Re: Sky stream
@Exiled-in-HHDo you enjoy trolling ?
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
Amazon 4K Firestick
Re: Sky stream
No... do you ... we are just having a discussion ... that includes sharing opinions and being polite😉
Exiled in HH
This message was authored by lettice This message was authored by: lettice
Re: Sky stream
The altnet ISPs that use sets of non determined UK IPs is a problem with Sky Q also, its not unique to Sky Stream.
We can escalate an customer, if their ISP is using such ranges, to add or investigate.
4g and/or5g home broadband works fine with Sky Stream and Sky Q if its using one of the EE, O2 or Three etc recommended 4g and/or 5g home broadband packages and dedicated routers.
One router that works well for many is the Zyxel range like the NR5103e.
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by marymcdonald240 This message was authored by: marymcdonald240
Re: Sky stream
Set up sky streaming set up
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Sky stream
@marymcdonald240 do you have an actual question or problem that you need the community's help with or are you just making a statement?
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
This message was authored by Annpearmain1958 This message was authored by: Annpearmain1958
Re: Sky stream
It is frozen
Re: Sky stream
@Annpearmain1958 wrote:
It is frozen
Have you tried unplugging it for a couple of minutes?
NOT a Sky Employee
