This discussion topic has been answered Discussion topic: Sky stream
Message posted on 14 May 2024 10:00 AM
Can you use sky stream with any broadband provider?
Message posted on 14 May 2024 12:12 PM - last edited: 14 May 2024 12:13 PM
@Scotty1956dex As you have already been advised by the previous post any BB provider can be used. At my location I can't even get Sky BB.
The important thing is to make sure you BB is fast and stable enough. Sky's minimum recommended BB speeds are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These are the speeds needed at the puck or Glass and not that being received by the router which can often be significantly different.
Message posted on 14 May 2024 10:01 AM
Re: Sky stream
@Scotty1956dex wrote:Can you use sky stream with any broadband provider?
Yes, you can.
HD = 25mbps
UHD = 30mbps
Message posted on 14 May 2024 05:23 PM
Re: Sky stream
@Scotty1956dex almost any .... there are some ISPs that have issues😉
Message posted on 14 May 2024 05:54 PM
Re: Sky stream
@Exiled-in-HH @Who are the ISPs that have issues ?
Message posted on 14 May 2024 07:12 PM
Re: Sky stream
The ones that use non U.K. IP addresses and users of Persimmon BB have reported issues, also those using 4G/5G mobile BB😉
Message posted on 18 May 2024 04:36 PM
Re: Sky stream
@Exiled-in-HH very niche then
Message posted on 18 May 2024 05:23 PM
Re: Sky stream
Yes but examples that not all are not not without issues😉
Message posted on 18 May 2024 06:32 PM
Re: Sky stream
@Exiled-in-HHDo you enjoy trolling ?
Message posted on 19 May 2024 10:36 AM
Re: Sky stream
@Anonymous wrote:@Exiled-in-HHDo you enjoy trolling ?
No... do you ... we are just having a discussion ... that includes sharing opinions and being polite😉
Message posted on 19 May 2024 12:14 PM
Re: Sky stream
The altnet ISPs that use sets of non determined UK IPs is a problem with Sky Q also, its not unique to Sky Stream.
We can escalate an customer, if their ISP is using such ranges, to add or investigate.
4g and/or5g home broadband works fine with Sky Stream and Sky Q if its using one of the EE, O2 or Three etc recommended 4g and/or 5g home broadband packages and dedicated routers.
One router that works well for many is the Zyxel range like the NR5103e.
Message posted on 06 Jun 2024 08:32 PM
Re: Sky stream
Set up sky streaming set up
Message posted on 06 Jun 2024 08:38 PM
Re: Sky stream
@marymcdonald240 wrote:Set up sky streaming set up
@marymcdonald240 do you have an actual question or problem that you need the community's help with or are you just making a statement?
Message posted on 21 Jun 2024 05:47 PM
Re: Sky stream
It is frozen
Message posted on 21 Jun 2024 05:58 PM
Re: Sky stream
@Annpearmain1958 wrote:It is frozen
Have you tried unplugging it for a couple of minutes?
