49
Discussion topic: Humming noise that disappears when using PCM
This message was authored by Grose6694 This message was authored by: Grose6694
My sky stream puck makes a constant buzzing/humming noise when audio is on.
Humming noise is only on sky and other sources on the TV don't make the noise. It comes out the TV speaker and only when a channel is not selected or if you are in the menu, when audio is coming out from a channel being selected it stops.
This message was authored by Addie15 This message was authored by: Addie15
Re: My sky stream puck makes a constant buzzing/humming noise when audio is on.
Posted by a Sky employee
Hi there, @Grose6694.  I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Any update?
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Hi so what is the fix please
Any update
This message was authored by Jporch316 This message was authored by: Jporch316
@Grose6694
Did you join the chat via the invitation the sky team sent you on this forum ?
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
I'm still yet to get a private message. No invite or notification to send a request
Any update...
This message was authored by The_Red_Silence This message was authored by: The_Red_Silence
I have this too.
You can get rid of it by selecting PCM audio out in settings, but then you don't get your Dolby Atmos.
I toggled it to Dolby Digital Plus and that worked for a week or so then came back so I'm back to copying with the buzz for now.
This issue is still outstanding.
still waiting on a Sky rep to get back to me on this for a weeks now.
This message was authored by Mark39 This message was authored by: Mark39
You've been invited twice now to a private online chat which you haven't responded to.....
This message was authored by KevNewMedia This message was authored by: KevNewMedia Answer
Re: Humming noise
Hi Everyone
Thank you for bringing this issue to our attention, and I offer our apologies for the problem.
So that we can investigate fully, can I ask for some further detail around the issue, please?
  • When you do hear this noise?
  • How would you describe the sound?
  • What is the name and model of the TV that you are using?
  • Are you using any AV equipment, if so, what is the name and model?
  • What sound settings do you have set?
I'll be merging some other discussions into the thread, so it may look a little out of sorts.
I've marked it as the answer for now, so that people can see the most up-to-date information.
Kev
Community Manager
Tom_-22
This message was authored by Tom_-22 This message was authored by: Tom_-22
I have changed the sound settings from Dolby to pcm stereo and it seems to stop the humming.
